Do I need a camber kit?
I plan on dropping my ride from the stock non-sport to as low as I can get it with my H&Rs ~2.5" in front, ~2" in the rear.
I have 18" RS4 replicas.
am I going to get some nasty tred wear?
RE: Do I need a camber kit?
Yes you are going to get some pretty good cambering of your tires. I'm not sure what's available out there to correct it either. You may have to live with low tire life.
you can "adjust" your camber by aligning your car only if the subframe is shifted, and only then will you be able to "even" the camber from side to side, not adjust it independantly or even take camber away
do all dropped a4s have camber issues? I was thinking about getting coilovers and dropping the car a bit (not crazy low, but low enough to make 18s look good) but if i'm going to blow through tires I might not do it.
ORIGINAL: Lazer Viking
believe me, if there was some way to get rid of neg camber i would do it
ORIGINAL: roll4ever
im pretty sure you can realign your car and get your camber and toe adjusted
