Diagnostic help
Diagnostic help
Well before I start to tear into anything and order parts I thought I would get another opinion. 2001.5 A4 1.8T quattro manual. Driving home from work and it started missing when I get into the boost at all. Anything over 3lbs and it misses. Engine light came on and was flashing. Parked it, scanned it and this is what I came up with
VCDS-Lite Windows Based VAG/VAS Emulator Version: Release 1.2 Ross-Tech: Home
Workshop Code: 000 65535
Diagnostic Trouble Code Report Monday, 08 April 2013, 15:23:22.
VIN Number: License Plate: Mileage: Repair Order:
Control Module Part Number: 4B0 906 018 CH Component and/or Version: 1.8L R4/5VT G 0002 Software Coding: 16701 Work Shop Code: WSC 63351 7 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent
17704 - Shareware Version. To Decode all DTCs P1296 - 35-10 - Please Register/Activate - Intermittent
16795 - Shareware Version. To Decode all DTCs P0411 - 35-00 - Please Register/Activate
16804 - Catalyst System; Bank 1: Efficiency Below Threshold P0420 - 35-10 - - - Intermittent
16395 - Shareware Version. To Decode all DTCs P0011 - 35-10 - Please Register/Activate - Intermittent
16684 - Shareware Version. To Decode all DTCs P0300 - 35-00 - Please Register/Activate
Readiness: 0000 0000
Im thinking that it is the cam tensioner is going and it slipped a tooth but again I wanted a second opinion before I tear into it. Luckily I have a second car to drive for the time being
go ahead and check it out but i highly doubt the chain skipped. its mor likely the belt skipped, but if it did it is very unlikely to be running at all as it wouldve kept skipping eventually
I replaced the plugs not long ago, same time that I replaced the bad coil. As of right now it seems to run perfectly fine at idle and in vacuum. If I get into the boost at all it will misfire like crazy. I am also getting a slight ticking out of the top end (again maybe tensioner)
