Dashboard won't light up help?
mine goes in and out (bright to dim) when i hit bumps. I started messing with the illumination brightness **** and it seems the problem is there. mess with it and see if it changes anything. Also check the fuse as brianjanice suggested
It might just be moving Scotch tape that bitch
Um I think it's fuse #5... pry off the end of your dash on the driver's side of the car (there's a little slot you can fit a screwdriver in). The fuses start at the top left - count from top to bottom to the 5th fuse... it should be a 3A fuse that is blown. Replace it. Otherwise, look for other blown 3A fuses in there - I can check what the fuse number is later if you can't find the broken one.
