cylinder 2 misfire!!!! help
i was driving back from work and as i parked the car to stop and get some snacks, when i cam back the car was sputtering and i have no power, sacanned it and PO302 came out as a cylinder 2 misfire, what are the steps to take to figure out what of the many things that can be wrong with my car
by the way does it have anything to do with my fuel tank being almost empty when that happened?
could it be an injector?
please help me out on this one!!!
RE: cylinder 2 misfire!!!! help
ok so here is what i did i disconected the coilpack from cylinder number two and switched it with cylinder number one and the coilpack from cyl 2 works perfectly on number one but the coilpack that was working stops working, there is no current from the plug or the cable.
steps to follow??
by the way its a 98 B5 1.8t manual
steps to follow??
No need, if its a pre-00 you need a new ICM. Swapping coils and spark plugs won't do s***t.
Go to www.ecstuning.com for a new one. Its the thing sitting on top of your airbox.
ORIGINAL: auditech79
ding ding ! winnar
im going with the icm problem, because it seems like the simples way to go, my question is this is it bad for me to run the car with this problem i know im wasting a lot more gas, but unfourtunetly school doesnt let me take a break while i am able to order this part and fix it!!!!!!!
