cyl 1 and 3 misfire
RE: cyl 1 and 3 misfire
depends, ive had my CEL come back on at 1 mile, 30 , or 200
go to my thread, should be near the top, and im uploading datalogs if you want to check out my parameters from my vagcom readings
ORIGINAL: TheBat
How does the ecm know what cylinders are misfiring? How long does it take for the monitors to come back on after reset?
I'll be welding in the new flex peice today, so we'll see what happens afterwards.
Not really. But I'm sure I can find a detailed description on the web somewhere.
I fixed the exhaust leak, and have been driving the car for two days, and NO CODES! The car runs smoother at idle and part throttle. The leak was very small, and I didnt know about it until I got the car inspected.
Now its time to do the stupid timing belt.......
i have the same problems now. ive changed all the air censors, fule filters now i will change the wires and different spark plugs, but most defenatly look for an exhaust leak. ive notice a weired sound coming from the exahust when i take off. any recomendations on exhaust systems i want to upgrade.
#18
Chances are its your exhaust then. When you take off, the motor rotates in the bay, pulling on the exhaust. Thats why all front wheel drive cars have flex pipes in the exhaust.
Jack the car up and look at the flex pipes, if they are torn, thats your problem. You could also run the car and run your hand around, you'll feel a leak. The cheapest way to fix it is to buy a flex pipe from ecstuning, cut the old one out and weld the new one in. You'll probably want to buy new rear exhaust clamps too. Mine broke getting them off, and I used conventional clamps, and they didnt seal at all.
Got any more q's let me know.
Russ Heinrichs
08-18-2021 12:39 PM
A4ENGRSF
10-09-2010 09:49 PM
