Crunchy Gears
Crunchy Gears
Anyone know what might be causing "crunchiness" when shifting between first and second gear, and what I can do if anything to fix it? Its a 99 2.8L manual. (I have a short sifter installed if that makes any difference)
-THANKS!
-THANKS!
It doesnt want to go into second gear very easily (takes some force) and isnt very smooth when it does, it is most noticable in the winter and when the engine is cold. Once the engine warms up it is definately better but still noticable. The same thing happens when Im downshifting into second or first gear under the same conditions.
I have not. I thought that might help aswell. I called audi and they told me that it would not help my problem and that it might make it worse for some reason, I dont know why. They said that my transmission would need to be torn apart or swapped to fix the problem. There is a DIY article on here that I read for a Tranny fluid change and he said that his shifts are smoother now, so maybe its worth a shot.
Check the trans fluid. If it's low or ugly, change it. It won't always solve the issue, but sometimes you can squeeze a few more miles out of it. Look for leaks while you're under there. Most common are the axle seals.
The resistance/grinding sensation is blocking rings/syncros. You'll likely need a trans rebuild, but a used swap might be the less expensive way to go, or at least less of a headache.
If it still happens after changing the fluid, you can double clutch and rev-match, but it's only a matter of time before you need to fix it.
i got the same exact problem and tried the fluid change with no luck. it did get a little worse even. if the trans is cold, i doulbe clutch and it works a lot better, but as far as i know my synchros are worn out. i either want to swap it or get it rebuilt. i dont think there is any other way around it
If your short-throw is improperly adjusted and causes you to miss shifts, then yes. Other issues that cause syncros to wear out are time, low fluid due to leaks, old fluid, pulling back on the shifter or resting the weight of your arm on it while driving, or missing shifts during those stop-light races.
most likely its your 1st-2nd synchro, if it only happens in that gear. If trans fluid or misalignment of the short shifter were the culprit it should happen in all gears. if you try and take it to a shop they will rape your wallet. its labor intensive but not rocket science. grab a service manual and free up a weekend. The part is relatively cheap.
