Cruise Control just stopped working??
So I am coming back from Vegas I used the CC to speed up and all of a sudden it stopped working. I have used my cruise for a couple months now with now issues. I went to check the fuse and there is not one there. Where should I check to fix this.
It's under the dash through the glove box. I soldered mine and it still doesn't work. I tested the switch with my voltmeter and it works fine. I think I might need a new vacuum pump
Those are pretty much the things that can go wrong... unless one of the vacuum lines came off your actuator.
Must be solar flares or some *****. Same exact thing happened to me today.
Worked on the way to soccer, did not work coming home (turned it off for a while, back on, nothing). Let it sit in the garage a few hours, worked just fine heading to the grocery store and back.
Anybody else ever have this happen and had a failure we can expect?
