Cruise Control
Cruise Control
Anyone have an idea what may cause the CC to not work? I have had the switch unit on the steering column replaced a while back and that did not resolve the issue. Someone mentioned that it could be a brake/clutch relay... not sure where or how to check this.
Any ideas if this may be it and where to find it?
Have a 98 A4 2.8 5Speed.
Will do! Thanks.
You guys are just guessing. It could be the vacuum pump, a leak in the vacuum system, the cruise module, the stalk switch, the brake switch, the clutch switch, the vacuum diaphram at the throttle. That system is (unnecessarily) complicated and you need to be methodical aobut how you diagnose it.
Read this, I've used it several times.
Cruise Control Diagnostic for Non-DBW A4 Ver.1 (Longer than Long) - AudiWorld Forums
Most common issues are the cruise control switch and the module... I had both. My first test was checking continuity at the switch, and I found out it wasn't making contact. Cleaned the switch, problem solved; or so I thought. Opened up the CC module and refreshed the solder on the 3 rectangular capacitors, and CC hasn't missed a beat since then! (been about 1.5 years)
If both of these fail to fix CC, then that guide becomes useful IMO.
chattyboy
09-04-2009 02:11 PM
Novo
03-24-2009 04:01 PM
A4 the Quattro
03-16-2006 07:07 PM
