Cruise Control?
Cruise Control?
Anyone have an idea where the cruise control relays would be located?
I replaced the unit on the steering column and that did not give me CC back. I was told there is a relay in the brake or clutch (beings I have a manual) area.
Need to know year, model, and drivetrain of your car (go to the new member area and see my sticky post about 2 actions for all new members - it'll tell you how to create a signature with this so you don't have to list it every time). In some A4s (like my 99) there's a cruise control box above the glovebox, brown in color and about the size of a pack of smokes. You can pull it out, remove the circuit card, and heat it with a heat gun to lightly reflow the solder - on some cars the solder cracked and caused issues.
Many people have partially or non-functioning cruise control in their B5's. I went on a 2,200 miles road trip with my dad summer '10 in my A4 without cruise control (my leg was killing me...) but it has since been fixed.
In my case the contacts on the CC switch were slightly corroded, so I cleaned them up. The CC still didn't work. Pulled the module as ImTheDevil suggested above, put fresh solder on 3 particular square capacitors on the circuit board, and voila my CC has worked flawlessly ever since.
Sounds like I am going to see about the box option as I had replaced once and cleaned once the control arm that the cruise control is on.
I've driven from Seattle to Tampa, Tampa to Boston and Boston to Seattle without CC, so I feel your pain!
So true. Mine partially works, in that I can set cruise but can't use the accel/coast functions. It's been that way since I bought the car in 2003, and it never bothered me enough to want to repair it to 100% functionality.
mine doesnt work and i drive 45 mins to school every day..... someone told me it was the whole tree that needed to be changed which aint cheap, so this helped me oeven and i will give all of these a shot to get CC finally. thanks
chattyboy
09-04-2009 02:11 PM
Novo
03-24-2009 04:01 PM
A4 the Quattro
03-16-2006 07:07 PM
