Coolant Change
Coolant Change
1993 90CS 2.8L V6 is the car. Where is the best place to drain all the coolant out? Didnt realize it when i bought it but it has green coolant in it and it needs to get out of there before it does any damage if it already hasnt. I know this is the b5 section but it gets more action then classic audi and the engine is almost the same as the 96 2.8.
the G11 is a green coolant too. since your car is that old it may be the G11, well it could be **** fluid too lol. what i did to flush out my system is let as much out as i could from the radiator and then kept the system going by pinching the return line and putting a hose in the reservoir.
I know ECS sells a blue G11. But i talked to the tech at the stealership and they said that i could put G12 in there so ill be picking some up on monday. And yes the coolant seems to be pretty wore out.
i would do a full flush with a bottle of coolant flush. basically you fill your system with water and a bottle of the flush fluid, drive it for like 20 miles, then flush it out with water and fill your system up with good coolant
