Control arms
Control arms
Ok so I'm looking to but some control arms on the Audi both need them so I can't do Meyle right now I was looking at the Vaico kit from Ecs tuning has anyone ever used them. I just can't afford to drop 500+ on those right now exspecially after recovery from my shitty timing belt experience I had so funds are beyond tight but they just need to last a year I don't care if I have to replace them next year cause I will be able to afford it then so once again the question is has anyone used them. And don't tell me to use the search button. Cause I would if there crappy mobile app would actually work for me for once because I don't have a computer to check so please some input
I just ordered the Vaico kit from ECS to install on my dad's car. I'll let you know what I think. I have the Meyle HD kit on my car.
BTW, I never use forums' built in search, they always suck. Just use google and put site:audiforums.com at the end of your search.
Audi-forums search is awesome!
The trick is you have to use the "advanced" search feature, then select "B5" section and the "key word" then click search, the search will find all the hits of the key work you choose, within the "B5" section.
Sorry, but you won't convince me to switch to using a forum's internal search. I ditched that method years ago.
If you want only B5 results, simply point google to the B5 forum. Pretty simple, and far fewer clicks than using the forum search.
So be it...
jdahlen24
08-25-2011 09:50 PM
jdahlen24
08-25-2011 03:05 PM
