Control Arm question
So I had my car up on a lift today and I really do need to change my frost left control arms. My question is can I just change the bushing at the wheel end of the control arm or is that part of the arm itself? Here is a pic:
The right side of this thing:
This end:
Can that be changed or is it the entire control arm?
Thanks.
This end:
Thanks.
Yeah I'm pretty sure the entire arm is going to have to go :'( Nick I would love to do all 4 corners but I don't have the cashflow right now, school is a bitch
Are control arms hard to do on your own? Doesnt look very complicated.
"That thing" is a ball joint. The bushing is at the other end. No, it can't be changed separately on these control arms - at least not without custom work to the control arm that would not really be worth it. They can on many cars.
I had the same ball joint go bad, myself. The entire arm needs replacement. Got it cheap from BLAUparts. I do remember the upper retaining pin was a bitch to pull out. Be careful not to over-torque the bolt at the strut.
If some are bad now, either the rest are bad and you just cant visually see it yet, or they will fail soon. Its really cheaper to get a full kit in the long run, wish I would have done that. And its generally harder than you might think, the pinch bolt for the uppers is a huge PITA usually (search pinch bolt), and sometimes the lowers dont like to pop out of the knuckle or will spin when you try to take the nut off. Pneumatic tools, a breaker bar, and patience are all nice to have.
