common leak areas in trunk?
Old 12-22-2010, 06:50 PM
Boober's Avatar
Default common leak areas in trunk?
I live in southern california and we've gotten hit with solid rain for about a week. My car hasnt been driven because it needs a new front bearing. opened the trunk today and found that everything is SOAKED on the right side in the corner of the taillight.
is there a spot where there tends to be leaks?
thanks
Old 12-23-2010, 06:40 AM
ImTheDevil's Avatar
There aren't really any weak spots that I can think of. Check the integrity of the trunk gasket that seals the lid when it's closed - you may have a puncture or rip in it, or the gasket may be compressed from age and time and not truly sealing it.
Old 12-23-2010, 11:24 AM
auditech79's Avatar
Its the sunroof drain, they back up and fill the trunk on either side. I would immediately remove the panel on the right side and get the central locking unit out of there because its probably submerged under water right now. Then either replace the sunroof drains (the back ones) or remove them, blow them out with compressed air, then re-seal the end pieces so excess water doesn't run down the outside of the drain.
Old 12-23-2010, 12:48 PM
Boober's Avatar
i dont have a sunroof, are there still drains? good thing my locking pump is already broken cause it was soaked. I'm trying to find another one on ebay etc right now but i think im going to mount it somewhere raised so it doesnt end up sitting in a puddle of water again
Old 12-23-2010, 02:40 PM
Audacity's Avatar
the tail light seal, you need a new one or to tighten the taillight. ps, your central locking control module is toasted...same thing happened to me.
Old 12-23-2010, 04:45 PM
Boober's Avatar
my module has been busted for a while, im about to buy a new one and im glad i havent put it in yet or it'd be f_cked
Old 12-23-2010, 09:45 PM
kayakman13's Avatar
An Audi with no sunroof!? :O
Old 12-24-2010, 09:37 AM
Audacity's Avatar
yeah but its def your taillight seal...i see it being hard for a trunk gasket to go bad. the taillight seal is just a piece of foam.
Old 12-24-2010, 11:07 AM
pbrules10's Avatar
thanks
I was having the same problem in the same corner. I put some duct tape on the trunk seal and it seemed to help. I would say go in the trunk and have someone spray a hose around that area so you can see exactly where it's coming from.
Old 12-25-2010, 01:59 AM
auditech79's Avatar
Oh you got one of the models without a sunroof, i've only seen two of them in my life, kinda rare actually. I think Mr. hood has one without a sun roof if i remember correctly. I would also say its the tail light seal, the trunk seal is a beast, and usually won't leak.
Quick Reply: common leak areas in trunk?
