coilpack help needed
Those codes are for cylinder 1 and 3. Are the coils in all the way? Check your coils and connectors.
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Misfire
No Spark
Possible Causes
Faulty Ignition coil(s) with output stage
Fuse(s) faulty
Wiring and/or Connector(s) from coil(s) to ECM faulty
Possible Solutions
Check/Replace Coil(s)
Check Fuse(s)
Check Wiring and/or Connector(s)
Possible Symptoms
Misfire
No Spark
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
