Codes - Throttle Valve Controller - ideas?
Finally got the alpha-bid VAG-COM to work on a friends laptop and got a code for Throttle Valve Controller Malfunction:
1 Fault Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-00 - -
Readiness: 0110 1101
Its pretty dark already so i didn't want to start taking things apart. In general what am i looking at and for? Is the problem electrical or to i just need to do some TBA? General symptoms are rough idle, stalling on start up unless i press the gas, stuttering around 2k rpm. Also is it something that can be fixed or am i going to wind u throwing 300 bucks for a throttle body? What could cause this?
I tried searching for it but most threads in different forums seem to go the "replace it and forget about it" way which is certainly not my first option. TIA
1 Fault Found:
P1545 - 35-00 - -
What car do you have? Specifically the year. This information relates directly to your problem and you need to provide it.
EDIT: huh if you type all in caps the forum fixes it to proper punctuation... il leave caps lock on from now on so i dont need to capitalize anything lol. but imagine what i typed except in all caps as if i really meant it.
just wanted to know if you were drive by cable or drive by wire. 2001+ cars do not have a throttle cable and are driven by electrical control only. since you have a DBC car, that code would probably be for the idle control motor in the TB (which keeps your car from stalling, etc), which isnt serviceable. you can try a TBA or some TB cleaner but i doubt that would do anything. more then likely your going to be buying a new TB.
shanemcconn
07-14-2009 08:41 AM
