Codes
Codes
1.8t AWM
Codes from the new b5.5... p1116 p1103 p1531 p0012 p0130 p1479 p1602 p1517. With out driving it and just letting it idle for a few mins the two that came back p1531 p1116.
So the P1531 is the Camshaft Timing Adjustment: Open Circuit which seems like it would explain the loud knock I have. Ideas?
P1116 is Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1: Open Circuit which who knows. I'm mostly worried about the P1531... I have a video I will post in a few mins of the car running...
Looks like your front o/2 sensor heater is shot.
You will have to also check camshaft adjuster for power & activation.
Anyone with 5000+ posts on the Audi Forums & own a Audi should own a Vag-Com by now! Just my opinion.
They have bi-directional testing & factory codes #'s that can help with diagnostics. You can also see what is a hard code & a pending code.
I'd start with replacing the pre-cat O2 sensor and the cam position sensor and see where that leaves you.
If we had factory codes to go on it would help.
Well the Audi's I own are OBD-I so no vag com but I do own 6 scanners which is how I pulled the codes! It's harder when I can't drive the car to activate new codes and it just has to idle. I'm already looking at a cam valve it's only $120 but I was asking if there might be any other causes to trip that code. Thank you though.
Correct me if I'm wrong but didn't the 01 b5.5 A4 have a AWM also? Which is why I cross posted it here. Same motor. doesn't matter if VW or Audi
You're right Don, its exactly the same motor. I was just pointing out to that dude that the term "B5.5" refers to Passats. 01.5 A4's like mine also run the AWM 1.8t.
