clutch is slipping...
Old 08-08-2008, 02:13 PM
czabelin's Avatar
Question clutch is slipping...
ive got a 98 1.t quattro and the clutch is slipping. any suggestions as to what clutch to get? im thinking about a stage 2 but dont know what brand...
Old 08-08-2008, 02:20 PM
ImTheDevil's Avatar
Southbend is a popular choice on this board - many people opt for them when they're modding their engines, so a stock or nearly-stock engine is unlikely to ever cook one. Plus, as you go about modding your car, it's not likely that you'll have to address the clutch again, as Southbend seems to build clutches with plenty of clamping force that should work for you for quite awhile.
Old 08-08-2008, 03:12 PM
czabelin's Avatar
yeah i decided to get stage 2 so the clutch can handle my torque upgrade because otherwise wouldn't a stock clutch just go faster cause it can't handle the extra torque?
Old 08-08-2008, 03:14 PM
ImTheDevil's Avatar
That's correct - if you make more torque than the pressure plate can clamp, you'll be spinning the disk against the flywheel while driving and will wear it out quickly.
Old 08-08-2008, 03:21 PM
czabelin's Avatar
and now that im replacing the clutch and putting in stage 2 does that mean i have to get a new flywheel or can i just resurface the old one becuase im only 17 and have a budget LOL.
auditech79's Avatar
Well on that same note if you get an extreme clutch like a 6 puck stage 5 or something like that it tends to tear apart the pressure plate surface. Puck clutches usually only have a life of 20-30 thousand miles. So getting a medium clutch like the southbend stg 2 would be good for long life because it uses a kevlar lining. Kevlar lasts literally forever but there is a very long break in period with kevlar, so you would have to baby it for close to 1,000 miles in some cases.
Old 08-08-2008, 03:23 PM
auditech79's Avatar
You can't resurface the stock flywheel, but you can scuff it up which is what i did. I wouldn't get a aluminum flywheel with a stg2 clutch either, you would experience way too much clutch chatter ( i know from experience) and reduced clutch life. Just re-use the stock flywheel, or buy another dual mass steel one.
Old 08-08-2008, 03:25 PM
czabelin's Avatar
1,000 miles wow ! i JUST got my ECU and i hadn't had it for one whole day and the clutch started slipping. so im trying to get a new clutch asap so i can drive it fast
Old 08-08-2008, 03:28 PM
auditech79's Avatar
Yeah the stg 2 can handle up to and around 300 at the crank, not much more than that. It feels stock when you drive it.
Old 08-08-2008, 03:30 PM
czabelin's Avatar
im pushing about 225 torque right now and im still not done with upgrades so im sort of stuck on what to do because eventually im going to get the k04 turbo.
Quick Reply: clutch is slipping...
