Clutch questions
Old 10-13-2010 | 11:42 AM
Reg Dunlop's Avatar
Default Clutch questions
Recently, my clutch has gone to the floor with no resistance on two occasions when I have tried to start my car. (97 1.8 Quattro) Once I pull it back, I can use it again. I am told it is most likely the master or the slave cylinder that causes the problem. My question: is there any way to tell for sure which cylinder it is? Thanks for any help.
Old 10-13-2010 | 12:15 PM
Mike-2ptzero's Avatar
You can check the slave to see if it is leaking.
Old 10-14-2010 | 11:29 AM
colony777's Avatar
could be some serious air in the line too. bleed your slave for starters to see if it helps. also, make sure your brake fluid is full, as your clutch uses the same fluid
xxbmxlsxx
01-23-2010 03:02 PM
Mike1.8t
07-27-2009 01:26 AM
Dallas09
11-10-2008 10:59 PM
skatemerica155
03-14-2008 03:58 PM
knyks342
05-21-2007 01:12 AM
Quick Reply: Clutch questions
