Clutch Insanity
Old 08-23-2008 | 01:07 PM
Mike-2ptzero's Avatar
Originally Posted by auditech79
The pedal going to the floor isn't just a hydraulic/pressure plate failure, it also applies to cars that completely lose their friction disc. I used to see it every day at the dealer, one side of the friction disc completely falls off from excessive heat, replaced the clutch and DIDN'T replace the slave cylinder and it drove fine.
That link i have does have audi listed in there, but since you have much more experience in the aftermarket world i will take your word for it. I personally would just buy a new flywheel though.
I guess that could happen on the stock clutch seeing that it already engages so high on the pedal, so if the material came off of the disk the pressure plate would need to travel even further to force the disk to the flywheel. This means the slave would need to be pushed further then it should go. That shouldn't be an issue on a aftermarket since they are all made to put the engagement mid or low on the pedal, so even if the disk failed the pressure plate still wouldn't be able to travel that far.
Yeah its just hard for people to shell out $500 to replace their stock flywheel when they can just have it resurfaced for $100 or less. Bad enough they are spending a good amount of money to buy a new clutch and labor. So that $400 is a pretty big savings. Its a different story when Audi is flipping the bill. Most people that do end up buying a new flywheel just end up going for a light weight single mass flywheel. Nice thing is that SB offers one that is 20 lbs, which is only 5-6 lbs lighter then the stock dual. But most people end up going for the 15-16 lbs spec Billet Steel single mass flywheel.
  #32
Old 08-23-2008 | 01:13 PM
onepoint8tee's Avatar
This is what I am considering:
http://cgi.ebay.com/ebaymotors/LUK-D...spagenameZWD1V
I'm just very stuck on a dual mass design in order to achieve stock smoothness, reliability, and NO CHATTER. A single mass will cause the enigne/tranny to absorb more of the shock of engagement, and thats the last thing my engine/tranny with 170k needs at this time....
  #33
Old 08-23-2008 | 01:20 PM
Good price. The Billet Steel 15-16 lbs Spec flywheel retails for around $395-$399. I offer free ground shipping to the 48 states, no handling fee's and discounted prices.
  #34
Old 08-23-2008 | 02:52 PM
auditech79's Avatar
I already offered him a brand new 16 lbs aluminum flywheel that i had lying around for free and he didn't want it, i guess he is really stuck on a dual mass lol.
  #35
Old 08-23-2008 | 03:22 PM
Lebe Frei's Avatar
not trying to thread jack but after reading this im wondering if i should resurface or just scuff up my flywheel? i guess it would depend on the condition its in..
  #36
Old 08-23-2008 | 04:41 PM
yumunsky's Avatar
Another thread jack...Im getting a new clutch myself, probably a southbend stage 2 with lwfw. The mechanic quoted me $1200 for labor, bringing the total cost to around 1700. Is this reasonable?
He also said something about how cars with quattro are much more involved when installing the clutch; is this true?
This is the first time ive ever taken my car to a mechanic and this dude seems pretty sleezy. any help would be appreciated
  #37
Old 08-23-2008 | 04:50 PM
Other than disconnecting an extra drive shaft, I don't know how doing the quattro is much more involved than fwd other than being careful to not let the driveshaft just hang there... and the tranny is bigger/heavier of course.. Same bolt pattern up to the engine and same cutch/pp/flywheel i believe. I've talked to a few different non audi techs about the job and all of them seemed to be way intimidated by messing with the awd for some reason.
  #38
Old 08-23-2008 | 07:45 PM
auditech79's Avatar
Damn thread jackers! 1200 for labor is a little intense, thats what the dealership would charge. Most shops would do it for 700-900, you could also find it for less. Changing an audi clutch really isn't that hard, un-less its an S4 or bigger tranny. 1.8T and 2.8L is stupid easy.
Chingy
01-15-2022 04:24 AM
99A4NOW
10-06-2010 10:04 AM
BaconBait
11-02-2007 10:53 PM
Matt_Iliketurbopull
04-28-2007 03:06 PM
Quick Reply: Clutch Insanity
