Clutch Insanity
Thanks, I suppose the real problem is lack bodies to help roll it into the garage! I had it set in my mind that I was going to replace the control arms while I had it in the air. I guess that can wait.
Same for the Sachs?
Same for the Sachs?
Re-surfacing the flywheel can increase the heat exposed to the clutch disc and pressure plate, so it would toast the new clutch in no time. Not to mention its almost the same material used in our brake discs which is very soft, so it tends to warp even easier when decreasing the thickness. You can do what i did and just scuff the stock flywheel up with a grinder and sand disc, as long as it doesn't have too many hot spots on they flywheel you should be ok.
I wouldn't suggest anything less then a Sach preformance clutch or a SB stage 3 for a chipped K03 setup.
BTW the SB stage 3 for a stock flywheel uses a Iron disk.
Is the stock clutch sprung? I've read that they are, but the OEM parts I see like luk and sachs are not.
nm. I finally learned that dmfw uses unsprung and smfw/lwfw uses sprung....Right?
Stock and after market use a unsprung disk for the stock flywheel. Sprung is for a LWFW. There is a guy(ian) that did get a sprung 6 puck from Clutch.net for his stock flywheel.
LOL, yeah that has to do with them wanting to sell you new parts.
#18
No, i have re-surfaced brake rotors before as well as other mechanics at the dealer and had the cars come back in 15 thousand miles because their brake pads had already worn out. Im applying that same theory to the flywheel. Places like 2bennett won't even let you re-surface the flywheel because they believe your wasting your money.
#19
#20
Well you can do what you want mike, im just giving the knowledge that i got from the transmission/gearbox class from audi in the ontario campus. I have had heard problems of that nature at the dealer before actually, clutch replaced 40k ago (2nd clutch) and now the pedal sinks to the floor and won't come up. I pull the tranny out and the clutch disc is completely destroyed. Its happened quite frequently when i worked at Niello. That could also be poor driving so who knows. There was some long and crazy explaination that i got from the germans about it, but it was like learning a foreign language.
