Clutch?
Old 09-02-2014, 11:49 AM
zero-o-matic's Avatar
Default Clutch?
so I have to replace the clutch on my 1998 Audi A4 2.8l 5 speed. looking to just flip this car and was wondering if anyone knows anything about Ebay clutchs/do I need to do the flywheel to or can I just do the clutch? just looking for a clutch so I can sell this one so I can start working on my A4 1.8l
Old 09-02-2014, 12:32 PM
MetalMan's Avatar
Moderator
Generally you can re-use the flywheel, but it's recommended to resurface the flywheel when replacing the clutch.
Old 09-02-2014, 12:34 PM
what if im doing it in my shop and do not have a machine to resurface it? can i just bring it to my job and use the brake lath to do it or? just not resurface it?
Old 09-02-2014, 07:41 PM
mtroxel's Avatar
An indy Audi shop in town here (he's a friend of mine) tells me no one in town here resurfaces dual mass flywheels. Not true where you live MetalMan?
Old 09-03-2014, 08:15 AM
A4TurboGuy's Avatar
I just replaced mine last week. Best practice is to convert to a single mass clutch & flywheel (both new). It's a cheaper and easier setup (that's what I did).
Either way: I wouldn't risk reusing/resurfacing an old (dual mass) flywheel. It could end up costing you much more. I've never met a expert who says it's a good idea.
Check eBay. You can get single mass, high quality HD clutch & flywheel pairs for pretty damn cheap.
Old 09-03-2014, 09:48 AM
MetalMan's Avatar
Moderator
I converted to single mass.
Some clutch companies like Southbend and Clutch Masters will resurface OE flywheels, but beyond that I dunno.
Old 09-03-2014, 09:51 AM
mtroxel's Avatar
When you guys convert to a solid flywheel, do you notice a significant difference in the engagement, or is it something your foot gets used to pretty quickly?
Old 09-03-2014, 10:04 AM
wait so the 1.8l is a single clutch? and the 2.8l is a duel clutch?
Old 09-03-2014, 01:02 PM
MetalMan's Avatar
Moderator
It's going to depend on the pressure plate. Some clutches will have different engagement points than others, most will have a lower engagement point.
1.8T and 2.8 both come with dual mass flywheels from the factory. Since the 1.8T has a larger selection of clutches/flywheels, many people choose to convert to a single mass flywheel to avoid potential problems with the stock (expensive) dual mass flywheel.
Old 09-03-2014, 08:58 PM
ive done the clutch in my 1.8l but not in the 2.8l before. is it the same?
Quick Reply: Clutch?
