Close to the 150,000 mark
I will soon be hitting the 150,000 mile mark on my car another 5,000 and she'll be there. I am now starting to wonder what I need to do to keep her on the road. Timing belt? Water pump? Not really sure. I am running a 96 2.8 quattro. Thanks
By the time you hit 150k you should definitely have done two timing belt services (including serpentine belt, tensioners, rollers, water pump, and thermostat). You may have failing wheel bearings and control arms to look forward to as well. Take a look farther down the forum for the thread called "Things that go wrong with ALL A4s" and you'll get a good idea of what others have had to deal with.
Wow that thread makes me feel pretty good about my car and that it only has a few issues, lol thanks man. I have already had the control arms done but I can also tell that the wheel bearings are starting to go any idea on how much $$ that is goin to cost? thanks again
The bearing is about $47 shipped from www.germanautoparts.com and most people have said that they're paying $250 or so for parts and labor at a shop, so figure that the shop probably charges close to $100 for the bearing and $150ish for labor (seems about right - two hours or so). Don't forget though that when the spindle is removed (at least on the rear) the camber adjustment bolt is removed as part of the process, so if its location wasn't marked before disassembly, you're going to have to align the car - that's extra and not included in the shop's quote.
