Climate controls not working!
Old 03-22-2009 | 12:05 AM
h4x0r's Avatar
Red face Climate controls not working!
The climate controls were working right until the two buttons on the right-bottom corner [air distribution selectors] got stuck in. Then the heater (it was on high ) wouldn't turn off and the other controls wouldn't work.
I can't get them un-stuck, but I can't... any suggestions?
Thanks!
Old 03-22-2009 | 12:17 AM
Audi_Skydiver's Avatar
Get some electric spray cleaner stuff and us that... also make sure its OFF when you do this.
josh
Old 03-25-2009 | 10:37 AM
h4x0r's Avatar
Red face Thanks!
josh
I'm going to try this out... hopefully it'll work.
Does this happen to you often?
Old 03-26-2009 | 03:56 PM
oleafo's Avatar
Had the same problem. I pulled the unit out so I could remove the face plate from the controls. Then soaked it in some water overnight. By morning the soda that got in there was soft enough to spray out with water and compressed air. I also gave it a good scrubing with a toothbrush. Just make sure everything is dry before you put it back together
Nordon
01-31-2013 10:59 PM
Ewald
09-28-2010 03:46 AM
charlie4616
09-19-2008 05:28 AM
JAGUAR
05-01-2005 06:07 AM
JAGUAR
04-30-2005 06:32 PM
