Climate Control Lights flickering, then off
Old 12-06-2009 | 08:21 PM
RSX664's Avatar
Default Climate Control Lights flickering, then off
First off, I'm new here, and this site has helped me a lot just through searches I have done. This issue has not been addressed, or if it has, I can't word the search correctly to find it.
My 1996 A4 Quattro has the climate control lights flickering in the temperature area. Sometimes they will go out and I'm left with faint white display, but the red lighting is gone. I removed the climate control, and moved the lights from the buttons to the center and the center lights moved to the buttons, and the buttons lit up, so I guess the bulbs are good. What could be causing this? The climate control functions like it should, but the lights go out and come on whenever they feel like it. It's near impossible to see the display when the lights go out.
Thanks in advance for any help you can provide. If this has been covered, please give me a link. I've seen the write up on how to solder the ribbon cables, but that was if the Climate Control didn't work, not if the lights for it didn't work.
Steve
Old 12-07-2009 | 12:54 AM
SAudi's Avatar
its a common issue with athe 12V believe me ive had 2. its either the bulb is loose or you have loose soldering in the head unit. this DIY should help.
http://www.audiworld.com/tech/elec153.shtml
Old 07-30-2015 | 08:18 AM
zubayer_2130's Avatar
I had the same problem with my '96 A4 1.8T. I have fixed it by re-soldering the climate control display unit.
Here is link for a quick video for reference if someone has the same problem in future -
hoovdiddy
07-05-2017 10:19 AM
adam73647
01-12-2014 10:45 AM
ryan_2012
09-09-2011 04:59 AM
timmay074
01-06-2010 11:20 PM
dunanga
01-25-2009 04:15 AM
Quick Reply: Climate Control Lights flickering, then off
