Cleaning old oil out of cat and exhaust
I just installed a new turbo and it's still smoking pretty bad due to the oil in the exhaust and cat from the first one blowing. Is there anything that I can use to help the process of getting all of that old oil out of there or will I just have to drive it and let it burn off? Thanks!
You can try taking the dp out and spraying some brake cleaner in that biatch if it doesn't clear up. You might need a new cat, though, because oil in it would likely ignite inside of it, which would raise the temperature inside of it and screw it up.
