circuit breaker....
alright so heres the update. i did some searching on audizine also and a lot of epople were saying to check the module that is in the trunk under the carpet behind the passenger side tail light. so i did that took it out. and it looks like there is some corrosion on the board from water. and the foam piece protecting it was also wet. so i took some alcohol based cleaner that we use at work for a lrage printer. cleaned the mother board plugged it in and it still doesnt work. so im thinking that is it just done. but i was wondering if after doing all this do i need to reset the circuit breaker or anything like that. or also anyone know where i can get another module from??
I'd say look for one at your local junk yard,then if there isn't a B5 there,try ebay. junk yard is your best bet,though.
