chip question not a normal question
Old 05-20-2008, 01:58 AM
kraylon's Avatar
Default chip question not a normal question
Ihave a mystery chip, and i have emailed giac,apr,revo,unitronic and none of them have any info on my car or ecu having their chip i also tried dahlback but i can't read german.
on my ecu there is no markings or achip inside. i run 18psi of boost, with good middle to high range power, and my car seems to like the bosch fd6dtc spark plugs over the ngk bkr7e or the bkr6e.
i bought the car used from pittsburg and the guy i bought it from doesn't know what chip it is i think what went on is that the former owener traded the stock ecu for a chipped ecu.
my question is is there a chip that is programmed to run the fd6dtc plugs and is there any way i can tell what chip i have that i have not already tried??
Old 05-20-2008, 02:40 AM
qUaTtRoA4's Avatar
Default RE: chip question not a normal question
I don't think that anyone tunes according to sparkplugs....
weird stuff
Old 05-20-2008, 10:47 AM
S_R_N83's Avatar
ORIGINAL: kraylon
You're not from Pittsburgh are you? I can tell by how you spelled it without the H on the end. There is an Audi/VW shop outside of Pittsburgh that chips. (They use APR) That's the only one I know of in the area that deal specifically with Audi and chips. If you want their info to maybe ask them, let me know.
Old 05-20-2008, 12:59 PM
feerocknok's Avatar
Usually the ECU or the chip inside of it has a sticker for the tuning company.
Old 05-20-2008, 01:16 PM
McGovs2.7TB5's Avatar
ORIGINAL: kraylon
Old 05-20-2008, 01:31 PM
feerocknok's Avatar
I won high jump in special olympics.
Old 05-21-2008, 01:40 AM
kraylon's Avatar
I didn't think they did but there has to be some way to elimate chips with the info i have given.
that info would be great maybe i can call them and they might have so info on it.
i forgot to mention that the car had a 5 bar fuel pressure regulatoralong withstock injectors. I also have a thought that the car was de-tuned before i bought it and returned to stock in some areas.
Old 05-21-2008, 09:14 PM
S_R_N83's Avatar
Next Level Performance Tuning
305 Beaver Street
Greensburg , PA 15601
724.219.4167
www.nltuning.com
Its worth a shot to try...
Old 05-22-2008, 12:56 PM
Zoidberg's Avatar
Dahlbäck is from Sweden
Old 05-23-2008, 02:26 AM
kraylon's Avatar
so is there a chip that puts out good mid range power, use a 5 bar fuel pressure regulator and likes bosch fd6dtc plugs
Quick Reply: chip question not a normal question
