Check engine light have codes
So check engine light came on and i got codes p0300, p0301, p0302 twice. Could this be because of spark plugs if so what do you guys recommend getting and from where, car is completly stock
Clear your codes.
Replace plugs first with NGK BK6RE. If it doesn't fix it, try swapping your coils around. If the problems stay with the same cylinders then you probably have a bad ignition control module. If they move with the coils them replace those coils.
