Check engine light
Check engine light
I have 98 with the 2.8. The check engine light was for a post cat bank 2. I replaced both cat's and all 4 O2 sensors. The light is still on. I have driven about 50 miles. Do I need to go to the dealer to have it cleared?
RedA4 I sure hope you didn't do all of that because of one CEL code for a post CAT O2 sensor! If you've done nothing to clear the code, its going to be there. Most auto parts stores will let you use their OBD reader. Learn how to use it. Hook it up and clear the code. Then see what you've got.
I have had the code cleared 3 times and it comes back in about 70 miles. So I changed out both along with O2. Both cat's were after market that I changed. I got the new ones from rockauto.com. They were OEM direct fit and they did fit perfect. I'm located in Schenectady, NY
Ok, that's not post-cat: that's pre-cat.
check this...since you've replaced O2 sensor and cats, take a look for exhaust leaks. But never rule out a bad new O2 sensor. You really need a VAG-COM and a Bentley for some good information.
16816/P0432 - Ross-Tech Wiki
VAG-COM is always for Audi. It reads the VW/Audi electronics modules. VAG-COM is what we all call it but it's kind of an old name...it's now VCDS. It's made by Ross Tech, read more here.
Ross-Tech: Home
You can get into it on the cheap (like I did and have regretted it) by buying an interface here, then registering VCDS lite at Ross Tech for another $99.
OBDTool.com
But I wish I had popped for the Ross Tech program where once you have their interface, any install of VCDS is activated. Then I could move between my garage PC and a laptop.
Do it Red. It will save you lots and lots of $$$$$.
Ross-Tech: Home
OBDTool.com
