Central Locking
Central Locking
Just a quick post if anybody has any ideas on how to solve my little problem.
The central locking works only if locked by key from the passenger door. It seems like putting the key in the driver door and turning it does nothing at all, but all 4 doors (and boot) lock by using the passenger door, so I have to walk around the car to lock it.
Any ideas?
Thanks.
Any ideas?
Thanks.
I would think the electrical switch in the key cylinder to signal the locking pump is bad. Does the driver door lock or unlock at all, but not the other doors? If so it sounds like some linkage in or around the key cylinder is damaged, you could take off the inner door panel and take a look.. If the vac line was damaged then the drivers door shouldnt lock or unlock from the passenger side either.
It's R reg, 97 I think.
The whole car locks from the passenger side.
Using the drivers door, nothing locks. The key turns but no actions after that.
It doesn't have a radio fob.
Hope that's more helpful.
