CEL's help.
CEL's help.
So Why does it say Cylinder 5. There is only 4 cylinders. Could my ecu be going bad?? Also what can I do about the Air Bag Fault. The HVAC says Excessive Common errors, does that mean I have a lot of vacuum leaks?
VCDS-Lite Version: Release 1.0
Wednesday, 22 September 2010, 12:03:47:0
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: 06B-906-018-AWM.LBL
Controller: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0001
Coding: 16001
Shop #: WSC 63351
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-10 - - - Intermittent
Readiness: 0010 1000
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
Controller: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D10
Coding: 0273004283
Shop #: BB 24332
No fault code found.
Address 08: Auto HVAC Labels: 8E0-614-111-ABS.LBL
Controller: 8D0 820 043 Q
Note: Excessive Comm Errors
Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
Controller: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 63351
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Controller: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 02244
Shop #: WSC 42202
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16232
Shop #: WSC 63351
10 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor; Front Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
01384 - Alarm triggered by Glass Breakage Sensor
35-00 - -
01386 - Trigger(ing) Alarm
35-00 - -
01387 - Wiring for Supply Voltage
35-00 - -
29-00 - Short to Ground
01392 - Next Output; --> Activate
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00200
Shop #: WSC 63351
End --------------------------------------------------------------------------------------------------
Coding: 16001
Shop #: WSC 63351
2 Faults Found:
Coding: 0273004283
Shop #: BB 24332
Coding: 00304
Shop #: WSC 63351
1 Fault Found:
Coding: 02244
Shop #: WSC 42202
Coding: 16232
Shop #: WSC 63351
10 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00101
Shop #: WSC 63351
Coding: 00200
Shop #: WSC 63351
I am glad to say that the CEL turned off yesterday. I didnt delete the codes it just went off by itself. I am guessing I had a dirty fuel injector because I ran tank damn near empty and the CEL turned off before I filled up. I just filled back up and drove around for about 10 mins and no CEL and it seems to run better. Thanks SeaFoam.
