CEL P0302 97 a4 1.8t NOT ICM UNIT.
I have a 97 a4 1.8t. Last year I was having random misfirings, while the car was shaking violently. Replaced the ICM. Problem solved. This year, car was shaking violently again, but this time only p0302. I had spare coils so I replaced all of them. Problem not solved. I then thought maybe the ICM was bad again. I replaced it with one from a local auto parts store. Problem not solved. Then thought maybe the replacement was bad, so I bought another ICM from a different store. Still not solved. Everything I read for p0302 is ICM, ICM ICM. But I am thinking either spark plugs, igniters, or wiring. Please help!
If you haven't changed your plugs then you should.. They're the first thing any shop is going to replace when a missfire is detected. Plus they should be replaced every 40-70k anyway as they become worn and cause the gap to get larger..
I forgot.. IDK how long you've had the car, but these cars are fairly picky about plugs.. I recommend the bosch double plats. If you get them DO NOT try and gap them.. They are pre-gapped and you will ruin the plug by trying.
