CEL codes, on then gone?
So i had a CEL on. Went to autozone they pulled p1237,1238,1239,1240. According to a list i found here.
http://www.bentleypublishers.com/tec....dtc.table.htm
That is Fuel Inj.Circ. Short to Ground on all four cylinders. It went away a short time later. Is this flashing on and then back off normal? Is it something I should be concerned with?
Thanks in advance.
BTW 1.8t, manual transmission. Quattro.
Thanks in advance.
I've heard from a shop tech at the local dealer that some codes are self clearing, and the ecu will clear it after so many good start cycles, but never that quick... Plus I'd think a fuel code would be a hard code (one that can't self clear)
