CEL Codes.
CEL Codes.
P1408
P1504
P0401
1996 A4
This is what I found online...
0401 - Exhaust Gas Recirc.Flow Insufficient Detected
1408 - EGR Temp.Sensor Signal too High
1504 - Intake Air Sys.Bypass Leak Detected
Do I need to take this in to get fixed? Can I do it myself... I'm completely lost.
P1504
P0401
1996 A4
RE: CEL Codes.
I know triple post... This is what I found online...
RE: CEL Codes.
The first two codes are most likely related. Chech your EGR with a vacuum pump for movement. Ok, then check EGR piping or clogged EGR port.
Third code is for either the Idle Air Control valve or a leak in the intake plumbing.
RE: CEL Codes.
I did some searching, all I find that might help you is this http://www.engine-light-help.com/egr-valve.html
The codes are definitely related to your gas problem from what i'm reading. Good luck, hopefully someone had a similar problem and can help you out. Otherwise try some other forums, someones bound to give you some direction.
