Care Bear Orgy
Old 08-21-2010, 02:24 PM
chocalotstarfish's Avatar
Super Moderator
Simple Solution... Find a friend close by... Open your trunk and ask him to grab that beer all the way up... When he reaches for it toss his *** in close the lid and tell him to listen around while you drive till he knows where it is coming from! Helps if the person knows Audis too...
  #22
Old 08-21-2010, 02:31 PM
briesa4's Avatar
Don where are you when I actually need you?
  #23
Old 08-21-2010, 02:33 PM
CCA4's Avatar
That reminds me, have you been able to re-create the noise when the car is standing still, or is it only when you're driving?
  #24
Old 08-21-2010, 02:40 PM
briesa4's Avatar
well when i get my fat *** out the car it will squeek ofcourse only on the driver side but standing still it wont make the noise
  #25
Old 08-21-2010, 04:11 PM
onepoint8tee's Avatar
Squeek from the front drivers side or rear when you get your fat *** out?? Front would indicate a lose CA bushing bolt or worn out ball joint/bushing. You said your CA's were replaced? I'd have someone double check the tq on those nutz-if the noise is from the front.
If from the rear, see if it makes this sound on level ground as you remove your fat *** out of the car without having the ebrake on. It could just be the pads squeeking on the rear rotor(s) as the weight of your fat *** is removed from the chasis. My rear brakes squeek a little as I get out of the car with the ebrake on when parked. If I were to engage the ebrake more, it wouldn't do this- try that too.
  #26
Old 08-21-2010, 04:48 PM
briesa4's Avatar
my ebrake isnt working so I park in gear its when i drive as well tho if I am going around a bend or turning its still from the driver side rear tho
  #27
Old 08-21-2010, 04:52 PM
Damn.. Don't you have a man-slave with tools that can check it out?!
  #28
Old 08-21-2010, 05:39 PM
briesa4's Avatar
I am in charge of the family mechanic business since my father had a stroke in nov so no im on my own for most things and... i refuse to buy new cables for the ebrake it works when it wants too
  #29
Old 08-21-2010, 05:56 PM
NickBroderick's Avatar
Stop being such a **** and maybe it wouldn't be so loose.
BYE!
  #30
Old 08-21-2010, 06:04 PM
joenelson7687's Avatar
dayum...
Quick Reply: Care Bear Orgy
