Carbonio Intake Install
So I'm installing my recently purchased Carbonio intake this weekend and wanted to see if there are any recommendations people have to watch out for. I know it is supposed to be an easy install, I just wanted to see if there were any things that people ran into that they weren't expecting.
Thanks in advance!
Thanks in advance!
It's pretty straightforward. I had to cut a bit from the front of the heat shield to allow the MAF to fit. I sealed the edge around the opening I cut with some hardening clay, held up fine for 3 years now.
It will take some fitting to get the height correct so it lines up with the hood seal.
Post some pictures when you're done.
Very easy install, I don't know if you are going to have the same problem but my cover wouldn't fit so I had to disconnect the one of the fuel line brackets and move the fuel lines over about 1/2". Other then that it's an easy install
Oh and I had to grind one of the screws on the maf so it would sit flush
Thanks guys! I figured it was easy. I really wasn't concerned at all but was curious about anything others have run into. I'm super pumped to get it on and see the results. I am also going to be on a hunt to find a vacuum leak because my boost is wayyyyy off. So once I find the leaks I shall be telling you guys how much I love the intake!
Okay good to know. Also, looking at it now(it just came in) how the hell does the thing sit in the bay? lol. I just don't understand it. I read the directions and it mentions like one bolt and that's it.
Yes, there is one bolt on the side of the frame that you loosen and slip the heat shield over, that is the height adjustment to get it all lined up. The cover bolts to the top of the heat shield and connects with the plastic snorkel.
Op I think you will enjoy the carbonio, you probably won't see a hp boost but I am pushing 2 psi more and definitely feel more torque (but my air filter was also relatively old so that probably has something to do with it ). I installed a test pipe at the same time as the carbonio and the combination of those two make a very nice whistle with diverter valve sound
