Car hesitation... Vag code! help.
Old 05-22-2008 | 06:06 PM
sobo's Avatar
Default Car hesitation... Vag code! help.
Hey. I own a 1997 Audi A4 Quattro. It's a 1.8l turbo 5 speed manual.
It has a Borla complete exhaust, K&N airfilter, and a MTM chip in it. THAT IS ALL.
The car has been running funny lately, hesitating when a lot of torque is needed. I changed the plugs, changed the air filter, changed the fuel filter, cleaned the injectors and changed the oil. Nothing.
I bough a vag-com ebay kit and ran the auto search. I got one code:
Address 01: Engine
Controller: 8D0 907 557 N
Component: 1.8L G1/5VT HoSp HS D05
Coding: 06201
Shop #: WSC 06435
1 Fault Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
Readiness: 0000 0000
1. First off, whats this mean?
2. Second off, what do I do to fix my car?
Old 05-22-2008 | 06:17 PM
auditech79's Avatar
Default RE: Car hesitation... Vag code! help.
It means you overpaid for your MTM chip LOL! No really it means that the engine management is seeing an overboost in the system, its a static fault so just erase it and see if it ever comes back. Probably won't.
Old 05-22-2008 | 06:26 PM
sobo's Avatar
Well the car hesitates, its just no random code.
I didn't buy the MTM chip it came with it haha.
Well, I'll clear that mother.. ttys
*edit*Codes not coming back...yet.. the problem is still there however.
Old 05-22-2008 | 07:32 PM
auditech79's Avatar
Check your vaccum line to the wastegate, check the lines to the N75 valve, also yank on your main intake hoses to see if anything is loose or come off.
ianjm
02-24-2010 06:51 PM
outinfront
12-30-2007 12:52 PM
eliTTe
09-30-2007 01:06 PM
duburban
01-05-2007 01:51 PM
bugbear
11-14-2005 06:28 PM
Quick Reply: Car hesitation... Vag code! help.
