car died - no oil changes for a year or so =)
Old 10-05-2010, 10:58 PM
hiwords's Avatar
fritz, you shouldn't own a car
Old 10-05-2010, 11:06 PM
twoeightquattro's Avatar
:'( i agree, you should not own a car.
Old 10-05-2010, 11:10 PM
fritz's Avatar
it is what it is.
the oil level was pretty low, as expected.
the timing belt has been replaced (at 100k, now is at 215k) as per the write up.
in your guys' opinion, is this worth saving? i think i would need a new turbo and while im at it, replace the belts/pump/tensioner again. anything else that could have gone wrong?
FASTER's Avatar
Tech Slut
What color is the car. I got first dibs on front fenders and hood if its black or silver. Oh and rain trays.
Old 10-05-2010, 11:13 PM
fritz's Avatar
too far, in california
Old 10-05-2010, 11:23 PM
well, depending on if there was friction in the cylinders, which there most likely was, you could have worn piston rings, gunk in the crank, etc. i'd just pull it apart and see what it looks like, theres no real way of telling until you do that. it's going to be way more than just a bad turbo and a few belts.
Old 10-05-2010, 11:54 PM
Msnickbroderick's Avatar
Actual WIZARD
If your in a screw it attitude, just fill the entire block with gas/seafoam, and let it sit for a few days. Drain, let it air out, and refill with oil. I saw that on a 1.8t vw thread.
  #18
Old 10-06-2010, 07:29 AM
CCA4's Avatar
What write up did you follow that told you to let your timing belt go for 115k miles!?
  #19
Old 10-06-2010, 09:30 AM
bradtyler02's Avatar
CCA4, I think we need a super epic face palm of all face palms for this one.
Fritz, find yourself a good man... (because this is totally a chick move right here)
  #20
Old 10-06-2010, 09:53 AM
CCA4's Avatar
Was just thinking that
Quick Reply: car died - no oil changes for a year or so =)
