car died - no oil changes for a year or so =)
#24
I'd be inclined to agree with this gentleman. Aside from the oil pickup/pump, the timing belt (and valves, cylinders, cylinder head if it did in fact snap), and sludge problem, the turbo shaft bearings are probably fried. Plus if it was as low on oil as you say it was, no telling how long the top end was starved for oil, the entire top end might be scrap metal anyway.
If you're feeling adventurous then by all means, try and save it. IMHO it's worth whatever you can get for it as scrap.
Also, not to be Debbie Downer, but if you couldn't even manage to change the oil or timing belt at the recommended intervals, what makes you think you're going to be able to tear down the motor and bring it back from the dead? Buy a Honda dude.
#25
its a 14 year old car and yes, i am in the screw it attitude. one tends to get bored of a car after so many years. it became more of a red headed step child after a while.
at any rate, the oil has been topped off throughout the year when it would get low, ticking valves would get louder, so topped it off.
the timing belt look intact but due. lets not assume. as i said, it was more of a boost problem before it gave out.
sure, the turbo bearing could have gone but the idea was to replace the turbo and not rebuild it.
if anything, i would assume at the least, sludge. ill check out the valve cover for s&g to see if it resembles the posted pic.
any helpful advice would be appreciated.
thanks.
thanks.
#26
thanks.
thanks.
I'm serious man just get rid of it and buy a new car with a warranty.
