car died - no oil changes for a year or so =)
it is what it is.
the oil level was pretty low, as expected.
the timing belt has been replaced (at 100k, now is at 215k) as per the write up.
in your guys' opinion, is this worth saving? i think i would need a new turbo and while im at it, replace the belts/pump/tensioner again. anything else that could have gone wrong?
well, depending on if there was friction in the cylinders, which there most likely was, you could have worn piston rings, gunk in the crank, etc. i'd just pull it apart and see what it looks like, theres no real way of telling until you do that. it's going to be way more than just a bad turbo and a few belts.
