Car died--need some advice
So about a week ago, I tried to start my car and it wouldn't start. Battery and everything is fine. Flat bedded it to a local VW dealer and they said cylinder head and timing belt need replaced. ~$4,000
What should I do? Should I just look to put a used engine in it? How much do they run?
Do you really think the head would need replaced since this didnt happen when the car was moving? It happened just when I wanted to start it up one day, and it wouldn't start
The car is a 1.8 tQ 2001 A4 with 150k miles.
A lot of that cost is labor. Be cheaper to do it yourself.
As for the head, they may have found evidence it's warped due to overheating.
Timing belt may be from testing, or guess on mileage.
Timing belts can go at odd times in odd ways. But since you didn't give enough information as to exactly what happened when you turned the key (did it turn over, did the dash lights come on, did it try to fire, did it smell like gas, etc.), can't say whether it's the timing belt or something else.
Is it getting gas? Are the plugs fouled? Are you getting spark to the plugs?
You can google replacement engines and they cost different depending on what mileage you want on them , or check Checker Auto for a rebuilt.
Timing belt may be from testing, or guess on mileage. The timing belt and all that goes with it was actiually replaced 50k miles ago, so I'm kinda suprised it went that quickly
Timing belts can go at odd times in odd ways. But since you didn't give enough information as to exactly what happened when you turned the key (did it turn over, did the dash lights come on, did it try to fire, did it smell like gas, etc.), can't say whether it's the timing belt or something else. Yes it did turn over, the dash/radio all worked, and now that I recall, I think I did smell gas slightly
Is it getting gas? Are the plugs fouled? Are you getting spark to the plugs? Spark plugs should have been fine
well best of luck to you... if ur gonna get a used engine why not look for the one everyone wants? i have no idea what year it came out of bu i read somewhere that one of the 1.8t motors was better than all the others lol
I found a local engine so I'm going to replace it. The car should be driving again in about a week.
