car all of a suden overheated
Hello to all, i was driving to work this morning, adn i noticed when i jumped on the freeway, the oil tem starting reaching to the middle, and it never did that, then the tempeture starting going over the halfway mark, and the the water signal started blinking, so i pulled over at a gas station, i checked the water and the oil, evreything was good, so i let it could down and jumped back on again, and the tempeture raised again, i started taking the street, and i noticed at low speeds the car does not over heat as much, it is when i reach over 40 the temps go up, too it to a local shop, they changed the thermo stat twice, he said the car still overheat, the car has had the timming belt changed and the waterpump, about 10k miles ago, any sugestions? many thanks.
if it was backwards wouldnt it have been doing this for the last 10k miles?
did you see coolant flowing in the tank when you looked? your first thermostat could have just failed and the place you took it to put it in backwards or something. or they didnt bleed it right and theres a big air pocket in there. is this a reliable shop or just someone you found in the phone book?
i have took my tt there as well, and they have done a good job, but when i first opened the hood, i noticed the coolent unit starting bubleing up when i opened it, and then the water started going down, ut i got the car back from the shop today, they tried 2 new thermostats, and it kept oin overheating, they said to take it t the audi dealer ship and let them diagnostic, the check engine light is on n ow, wich wasant when i took it in the shop, also, the oil signal came on b4 i took it to the shop it started blinking, but like isaid, all oil levels were good, so tommorow morning im going to the audi dealer for up 150 just for them to tell me what the probblem is, il keep you all updated, sorry for the misspells im just pissed.
Sounds like it might be air-locked. Or they may have also used a crappy water pump which broke. Do you have flow to the tank? Pull the small hose to the overflow while the car is running.
You also might want to check out your ECT.
A. they broke something and want the dealer to fix it. dont pay them.
or
B. your oil light came on flashing you said- that means you lost oil pressure...? usualy by the time that light comes on you may not even have 5 seconds to turn the car off before toasting something, so it may not be their fault if the CEL came on after that.
