cant find ac drain
cant find ac drain
My pass side floor is all wet. i cand find the drain tube at all. I seen on here somebody said its on the pass side behind the kick panel but i dont see it at all. does any on know were its at 96 12v thanks. pics would be a plus
I just went through this in my 96 as well. Its a bitch to get to from inside the car and hard to locate from underneath. I dropped my glove box and lifted out the carpet and sound deadening material to get to it. There are 3-8 or 10 mm nuts that hold the plastic drain 'cup' and tube to the firewall. These are a pita as they are hard to reach. I think I used a 1/4" ratchet and universal with an extension to get to it. After it's out you can make sure its clear in both directions. Mine was blocked above the drain and gave me quite a bath when it let go so be prepared. I found a DIY with pics somewhere, if I find it I'll post the link.
ac, air, airconditioning, audi, conditioner, conditioning, drain, drainage, find, garage, service, tube
