Can Anyone Help With These Diagnostic Codes?
I took some of your advice and managed to get my car to autozone to get the codes...well it put out 5 codes...
P1128, P1613, P0300, P0304, P0302.....The chick said the last 2 or 3 are cyclinder misfires which can maybe be fixed by new plugs/wires...but I had no clue about the other codes. Can anyone help me out? Thanks I REALLY apprecaite the help!
RE: Can Anyone Help With These Diagnostic Codes?
Okay i figured out 300, 302, 304 and they all deal with the cyclider misfires. P1128 says: Long Term Fuel Trim Mult., Bank 1 System too Lean....and P1613 says: MIL Call-up Circ Open/Short to B+....I have no idea what those last 2 even deal with....so any advice about what the problem could be?
Unfortunately, I don't have my diagnostic book with me (out of town).
1128 check vacuum lines, try to clean your MAF with some TV tuner cleaner spray from Radio Shack. Next would be precat oxygen sensor.
You don't say what your problem is, so I can't of more help.
The car won't stay idle...It starts up and runs for maybe 1-2 seconds and then dies. The only way I could get it to autozone to get the codes was to put the brake down give it gas while at the same time putting it into drive. Even when I got going it was making a puttering sound and everytime i slowed down too much or stopped it would die again. By the time I got the car home it was actually staying idle, but the RPMs were fluxing between 1 and 2. Any idea with those symptoms and with the codes that I got what the problem might be?
