Camshaft position sensor
Hi.
I have an ATW 1.8 LT turbo with the service engine light ON. checked the codes and they told me the camshaft position sensor is the fault. The question is how to replace that sensor, is it as easy as removing the old and installing the new? I think this is the one that goes by the timing belt. is this correct?
any help is greatly appreciated
Thank you
Thank you
just remove the engine cover, then serpentine belt cover. If memory serves me correct it will be on driver side front of the block, two bolts hold it in. Disconnect connector then install the new one. 15 minute job.
Peterhopson84
08-20-2013 09:57 PM
jkjersey
B7 Models
06-17-2013 09:31 AM
