Cam locking tool
Cam locking tool
Ok decided to tackle the timing belt job. I'm looking for the cam locking bar I didn't want to pay 180 from Ecs or the 300 to rent from blauparts. I looked on ebay there's a bunch on there from 30-50 with the crank lock pin also has anyone tried the ebay tool and feedback. Oh and it's a 96 2.8 12v qm
That is the least precise tool imaginable. Its pretty hard for a cheap eBay one to let you down. Just know that you need the 12 valve tool: its a little shorter than the 30 valve tool. A lot of them are adjustable so they fit either motor.
It's not the tensioner it's the dampener. And Ecs kit is stupid it only includes 1 cam seal with it hello it's a v6 there's 2. If I go with blauparts it comes with the same stuff as the Ecs kit but comes with both seals and they have a deal for your serptine belt tensior for 25 with purchase of timing kit
http://www.blauparts.com/proddetail....od=GH21111%2DB
Sorry, got 'cha on the dampener. I've gone both ways on that. Its not like its a spinning part so you wouldn't think its wear rate would be as high. And frankly, some of the new cheapo aftermarket ones I've seen looked less trustworthy than the factory one with 90,000 miles on them. On the other hand if that belt goes slack.....
Weird with the ECS kit. I wouldn't let that make the decision. I bet it was just a typo, and if not, even at the dealer a cam seal's a pretty cheap part.
That roller's bolt is a single-point failure part if there ever was one, so use a decent torque wrench when tightening it. If it were to loosen, the roller hub might rotate and slacken the timing belt enough to jump sprocket teeth.
s31523
09-29-2010 04:28 PM
