A/C Problem
A/C Problem
my a/c is acting up, it runs cold for a while and then it will blow just air kinda muggy. the compressor starts and a/c fan all going at the same time when stopped, but then the compressor turns off and so does the fan. it'll start up some times, and others times it'll just blow muggy air. any ideas?
my guess, might just be low on freon...just remember, too much freon makes it do the same thing, and don't buy that fix a leak stuff at the auto parts stores, it will damage a mechanics a/c machine if and when you decide to take it in to get it fixed...I think it's just low on freon personally...I'd have it tested though with a good audior A/C shop....
Good on freon, took it to mechanic and they checked the freon, all good. It seems that the compressor loses power completely. Checked electrical current and no power was getting to it, but then it'll turn on all of a sudden. Mechanic need the a/c electrical scheme, to find the source of the problem.
Here's a pdf from bentley publishers for a b6 A4, might help though....
http://www.bentleypublishers.com/ima...i.b6.wd.02.pdf
