buying an avant tomorrow would like some opinions
Old 02-12-2014, 01:23 PM
smokejunky's Avatar
I've been searching on here for about a week.the things I seen was it's one of the better engines they make. I asked and he doesn't know when the TB was changed so I'm going to order the kit that I seen on here.cant Rember the site though haha I know they alot of stuff European cars.he also has receipts for all the work he has done on the tranny and engine work.
Here's the link
http://bozeman.craigslist.org/cto/4270775316.html
Old 02-12-2014, 01:37 PM
smokejunky's Avatar
The parts place is blauparts what's the difference between the enhanced kit and the enhanced with the race belt?
Old 02-12-2014, 02:08 PM
MetalMan's Avatar
Moderator
Be careful... the seller seems to be giving false information. They say "turbo 2.8" but in fact there is no turbo.
Old 02-12-2014, 02:10 PM
Huskerbob's Avatar
+1 on MetalMan's comment. NOT a turbo engine. The enhanced Blau kit w/race belt will do the job. You know you need to pull the front off to do the timing belt? Search the forums for instructions. Not too difficult and make sure you rent the tool kit from Blau as well. Good luck.
Old 02-12-2014, 02:17 PM
Huskerbob's Avatar
2 other items you should check. Make sure the heater blows hot air and he's asking too much for the car. $2000 max. IMHO You don't need to be paying for his transmission work.
http://www.kbb.com/audi/a4/1999-audi...condition=good
Old 02-12-2014, 02:22 PM
smokejunky's Avatar
I seen that some maybe it was just a typo.i just sent him a message about it though.im in the AF and we have a mechanical shop on base so hopefully they have that tool if not I'll grab it.i did read about the front clip.is that racing belt just a stronger one?
Old 02-12-2014, 02:26 PM
smokejunky's Avatar
I'm in MT so heat is a must lmao.also in MT cars are alot more than say the east coast so I don't know it seems pretty immaculate though
Old 02-12-2014, 03:21 PM
Huskerbob's Avatar
Thumbs up
get the tool kit from Blau. You need the crank lock pin, the cam lock bar, the pin wrench, the spanner for the fan and your shop on base does not have those I bet. Can't do it without those tools. Follow the instructions carefully or you will grenade the engine!!!!! Timing is critical. This is an interference engine and if you get it wrong it will crash the pistons into the valves. Then you get to do the heads.
You decide what to pay. I'm just saying that he's overpriced by a factor of 2 but it's your money. Thanks for your service!
Old 02-12-2014, 03:25 PM
Huskerbob's Avatar
Here's a video of your engine timing belt change at a shop by a mechanic who has done it thousands of times. Read up on it before you dive in.
Old 02-12-2014, 08:42 PM
smokejunky's Avatar
Thanks that dosnt look to bad. i called the shop and they said 120 for the labor haha.i thats the real price that will be great.
Quick Reply: buying an avant tomorrow would like some opinions
