Brakes issue
Brakes issue
Lately my brakes have not been working. I'll be driving at say 40-60mph and then hit the brakes to slow down and they don't respond - the pedal just gets rock-hard and nothing happens.
Can someone tell me what the issue is?
Thanks.
Car - 2001 A4 72,000 miles, 1.8T.
RE: Brakes issue
The pedal gets rock hard? Usually when the master cylinder is going, air in the system, the pedal gets really mushy and has extra travel.
If the pedal is hard, doesn't move very far, and doesn't do much, it could be the brake booster.
RE: Brakes issue
A hard brake pedal could be due to a clogged up reservoir. Have you tried sucking out the reservoir and flushing the brakes with new fluid?
Another possibility is an ABS issue. Do you have an ABS light?
RE: Brakes issue
Possibly, if there is an ABS issue. The tone ring is on the outer CV. If it's cracked or full of grease, it could be an issue. Do you have an ABS light turn on with key on/engine off? How about if you test the instrument cluster with the *****?
