Brake squeak at low speed
Old 05-08-2008 | 06:53 PM
compmanben's Avatar
Default Brake squeak at low speed
OK I haven't looked into this yet, but I have a sqeak coming from what I believe is the front left or front right brake. Here's what happens - at low speeds (less than 20) I'll hear a periodic squeak, but it goes away if I hit the brake. I believe I have plenty of pad left... Any suggestions for things to try?
Old 05-08-2008 | 07:55 PM
hiwords's Avatar
Default RE: Brake squeak at low speed
ok at low speeds, you hear a squeak b4 you apply the brakes but it goes away after you apply the brakes?
Old 05-08-2008 | 08:03 PM
compmanben's Avatar
Correct
Old 05-08-2008 | 08:42 PM
hiwords's Avatar
hm maybe your pads are touching and when you apply the brakes, it pushes the pads back towards the calipers. check your inner pad, it might be slighty loose. also spray your brakes with brake cleaner.
DewAudiA4
03-18-2013 12:04 PM
03A41.8T
04-08-2008 11:13 AM
SuperVan
03-30-2008 04:19 PM
brrman
06-01-2007 12:06 PM
turboavant
05-06-2007 05:47 PM
